XFX GeForce 9600 GSO 680M XXX Edition
Written by Tim Smalley
September 22, 2008 | 07:55
Tags: #4670 #9600 #9600gso #edition #evaluation #geforce #gso #hd #overclocked #overclocking #performance #radeon #review #xxx
Companies: #amd #ati #nvidia #xfx
Crysis
Publisher: Electronic Arts
What can we say about this game that hasn’t been said already? Crysis was probably the most anticipated game on the PC last year and was released on November 16th 2007.
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 30 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
For our testing, we set all quality details to medium except for sound detail, shader detail and texture detail, which were all set to high. We also forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x and 4x anti-aliasing and 1,680 x 1,050 using 0x and 2x anti-aliasing. By testing at reasonably high detail levels and with anti aliasing, but at lower resolutions, these tests will give a sound idea of performance on the systems these cards are currently targeted at.
XFX GeForce 9600 GSO 680M XXX Edition Crysis DX9 XFX GeForce 9600 GSO 680M XXX Edition Crysis DX9
Crysis
1280x1024 0xAA 8xAF, DirectX 9, Medium Quality, High Shaders and Textures
  • XFX GeForce 9600 GSO 384MB 680M XXX Edition
  • BFG Tech GeForce 9600 GT 512MB
  • Asus EN8800GS/HDTP/384M
  • Sapphire ATI Radeon HD 3870 512MB
  • AMD ATI Radeon HD 4670 512MB
  • HIS ATI Radeon HD 3850 512MB
  • Inno3D GeForce 9500 GT 512MB
    • 35.5
    • 21.0
    • 31.2
    • 18.0
    • 30.3
    • 19.0
    • 28.2
    • 13.0
    • 26.4
    • 15.0
    • 24.1
    • 14.0
    • 13.4
    • 7.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1280x1024 4xAA 8xAF, DirectX 9, Medium Quality, High Shaders and Textures
    • 27.0
    • 17.0
    • 27.0
    • 16.0
    • 23.3
    • 14.0
    • 20.3
    • 12.0
    • 19.4
    • 11.0
    • 17.2
    • 10.0
    • 11.3
    • 6.0
10
15
20
25
30
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050 0xAA 8xAF, DirectX 9, Medium Quality, High Shaders and Textures
    • 28.2
    • 19.0
    • 24.9
    • 16.0
    • 23.9
    • 16.0
    • 22.3
    • 10.0
    • 20.7
    • 12.0
    • 19.1
    • 11.0
    • 10.6
    • 6.0
10
15
20
25
30
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050 2xAA 8xAF, DirectX 9, Medium Quality, High Shaders and Textures
    • 21.4
    • 14.0
    • 20.6
    • 14.0
    • 17.8
    • 12.0
    • 16.0
    • 10.0
    • 15.1
    • 9.0
    • 13.5
    • 8.0
    • 8.8
    • 5.0
10
15
20
Frames Per Second
  • Average
  • Minimum
Unlike DirectX 10 mode, Crysis' DirectX 9 mode is a lot more palatable for these mid-range cards. XFX's GeForce 9600 GSO XXX Edition follows the same trend that it did on the previous page - it's the fastest card pretty much right across the board and delivers much higher frame rates than the ATI Radeon HD 4670. What's more, these frame rates are playable up to and including both 1,280 x 1,024 4xAA 8xAF and 1,680 x 1,050 0xAA 8xAF with shaders and textures quality set to high.
